- Joined
- 25 Jan 2012
- Messages
- 118
- Reaction score
- 3
- Country
So I'm intending to put up ewi. Solid brick so wanted to use mineral wool.. however I have a very narrow path 'just' enough to get a wheely bin through.
What I wanted to do was place 130mm everywhere apart from in this section as to keep the pathway.. and so in this section I would use aprox 80mm (dependent on final measurments). problem is that the 80mm will not perform to building regs. I could put a more performant insulation xps or eps but then they would not be as breathable. Given it is solid wall I really want the whole element to be as breathable and to keep the mass of the brick for thermal retention so I really dont want to put internal insulation unless I can avoid it..
How should I approach this with BC are there any ways around it?
What if the remainder of the property was speced above the required U values?
