Hi.
Does anyone have an idea for the best way to remove thin layers of silicone.
I've just sealed a few areas in my en-suite using a semi rigid spreader.
The finish is excellent, but there's a very thin layer left behind on both sides of the main bead of silicone.
it's only partially noticeable in dry conditions, but when you use the shower you can see it a lot worse.
I want to know if there's some type of solvent that will let me wipe the excess off without it attacking the main part.
Thanks.
Thanks.
