Does anyone have experience of using an extension hose on an expanding foam gun? I have a 'gun-grade' set up, and need the equivalent of a 1.2 metre extension pipe on it.
If I did it with an 8mm inside diameter plastic pipe then my guess is it'd work for the first couple of minutes, but then does it gradually gum up and write itself off, or does it remain serviceable for an hour or two before you have to bin it and start again?
