Expansion Vessel again!!
17 Nov 2007
Cambridgeshire
Hi, Just a quick and simple question and a simple answer, I hope.
I have two sealed systems, one has a vessel with an inlet to recharge with a footpump or similar, the other does not appear to have such a connection. Am I missing something?? In both senses?
It is the latter that I have problems with, which I believe is defective due to the normal symptoms.
Nick
All sealed systems have expansion vessels, and a filling arrangement for WATER. Is that the one you're looking for.
Expansion vessels do all have an air-filling valve, but that rarely needs attention.
Is this one part of the boiler? If so make & model otherwise is there a makers name model on the vessel?
Any chance of a photo?
Yes that is the one. I guess it is just a simple case of replacement in that case.
The symptoms are, if I charge to say 1bar cold, when the system runs it goes to around 3bar then it discharges some water through the valve. When system cools, pressure drops to sub 1bar.
I can presume the diaphragm has gone!!
Nick
typical symptoms of a duff expansion vessel. If it had a shraeder valve (like a car tyre) it would be easy to tell.
It has got a schraeder valve.
Clearly xild is not a plumber or heating engineer. The 'tamperproof cap' he read about in the specs on the internet is just a circular plastic cover which unscrews.
I think it is very useful for a forum to take advice from all; its just that a novice may assume what they read to be correct.
I see that xild's last posting got him into some trouble and he retrospectively edited out all his text with 'abc'.
Perhaps he could do the same here?
Hi Simond,
If as you say it has such a valve I would be very interested to know exactly where it is on my particular vessel?!
Nick
You can see where it is on the brochure linked to above. It's under a plastic cover at the opposite end to the water connection.
So its at the base of the vessel. Thats a real pain as the vessel is installed sitting on the floor so access to the base is not possible.
I take it from the symptoms I have that replacement is a real probability. If I have to drain, disconnect in order to gain access to the base and coupled with the fact that the relief valve has activated, so I understand that should be replaced, I am probably best advised just to replace.
In any case for this to happen so quickly, I doubt refilling of the vessel will assist, if in fact the bladder is still complete inside.
Any thoughts?
Many thanks,
Nick
Well worth recharging the air side. More often than not it's all that's required.
