Exploding windows
17 Jan 2009
Sheffield
about 4am there was a crash from downstairs, we went down to see what had happened and the inside pane from the double glazing had shattered, no damage to the outside pane!!! Any ideas on what might have caused this???? :shock: :shock: :? :shock: :shock:
aliens like the ones that managed to negotiate themselves for millions of light years across space without hitting anything then flew into a wind turbine
Its more common than you may think
A cold night, a warm room, and a bit of a flaw/stress in the glass or a bit of pressure from a packer or suchlike and bingo.
Search this forum and there are several recent posts about this
A sharp drop in outside temperature & the outer pane shrinks more quickly than the inner; all you need is a stress point & “Bang”. This can be caused by a screw, poorly fitted glass packing, twisted frame or even poor manufacture/assemble of the glazing unit itself, maybe a small nick in the glass where the panes are sealed or a piece of debris in the mastic sealing but just try proving it's a manufacturing fault; & it's very unlikely your warranty will cover it!
This does seem to be happening more with low E coated glass (“K” glass) than older DG units which, by design, means there could be a significant difference in temperature between the out & inner glass panes!
