I want to add two sockets to a ring main. Because of accessibility problems I intend to cut into a leg of the existing ring, join a length of 2.5 to each cut end and take both legs to a new socket, then spur off that socket to the other socket.
My question is, As the joins will be under the floorboards, I believe I cannot use JB's. I have looked at past posts regarding this and it is suggested that the joins be crimped then put in an insulated enclosure (or use heat shrink). Could someone point me in the direction of a link as to the best type of 'insulated enclosure' to use please.
Whilst on the subject of JB's and the need for accessibility. If you are re-wiring the downstairs lights and none of the lights are loop-in pendants, and the switches are 2 way multi-gang (ie, crowded already without having to loop in/out at the switch), then what other options do you have other than using JB's.
