Extending a Washine Machine Hose
5 Jul 2007
Hi All,
I need to extended a washing machine hose. The current connection is a female thread - but it needs to be connected to a spigot on the sink trap.
Any suggestions?
Cheers
A couple of jubilee clips on the connector should do the trick. If you want to be doubly sure, put a few wraps of ptfe over the clip's spigots before you push the hose on and jubilee it down.
thats useally what you would use when joining two waste hoses.
but i can't see why yours has a female thread on the end.
have you a pic ?
have you a pic ?
You don't suppose the op is getting confused with a waste hose and a blue/red connection pipe?
i don't know, his confused me.
Or has the OP still got the spigot usually supplied as part of a waste trap still pushed into the end of the waste outlet hose?
Washing machine outlet hoses usually have a plain end that can be either formed into a crook shape and hooked into the top of a washing machine trap standpipe, or pushed over a barbed spigot that's part of a sink trap, and usually clamped with a hose clip.
Usually you can pull out the spigot, leaving a bare hose end, then fit a hose extension kit, which comes with a double ended barbed hose connector and clips to join the hoses.
Or buy a replacement drain hose of an appropriate length to replace the hose on the machine
Or install a seperate washing machine trap adjacent to the machine.
