Sorry to bother you.
There is probably a simple answer, but I tried in vain to change a single three pin socket for a surface mounted double socket. The only problem is the wires are not long enough to be secured in the surface mounted one. (Whoever wired in the single one obviously had problems as it fell off the wires without me undoing the screws when I took it off the wall!)
Anyway I tried to pull the cable through a bit more with a pair of pliers but they wont budge. I have managed to reconnect the old single socket (making sure the screws holding the wires are tight) and put it back.
So how do I extend the wires? Is there an easy way with a terminal block, or do I have to wait till I redecorate and use a junction box?
Many thanks
Mottsy
Many thanks
Mottsy
