Extension roof rendering is loose
30 Jul 2013
London
Hello
The rendering on our extension roof has come out a bit (see picture)
Can someone please guide me what do I need to buy and do in order to put it back together?
Sorry loose flashing (wasn't sure about the right term for this)
Anyway, simply attempting to put it back doesn't work, is there some sort of material I need to apply in order to put it back together?
As above.
You could remove the length of loose lead flashing,
and clean out the mortar bed, and then slip the flashing back into the bed,
drive in a couple of lead wedges to hold it in place,
and point up in sand and cement.
wedges are little off-cuts of rolled up lead.
The roof covering seems to be fibre cement slate - is this the case?
