    Dismiss Notice
exterior wall render
Discussion in 'Building' started by rasputine, 26 Feb 2019.
  1. rasputine
    rasputine
    7 May 2016
    14
    Thanks Received:
    Country:
    Hi i am looking for a filler for a exterior wall, that has been rendered with what appears to be a semi flexible material. I imagine this was done to cover failed pointing or prevent damp penetration. The problem is that some of the surface has cracked and peeling, the majority of it is OK, but i thought it best to make good those parts that are bad. i need some advise on whats best for the job, as having it striped and rendered will cost close to £3.500. would welcome any advise on this as i need to make the best of the dry weather and get it sorted.
  2. Sponsored Links
  3. KenGMac
    KenGMac
    24 Aug 2010
    3,822
    Thanks Received:
    743
    Ayrshire
    Country:
    rasputine, good evening.
    Generally, how deep are the cracks and how long are they?
    Ken
  4. ^woody^
    ^woody^
    3 Sep 2006
    33,622
    Thanks Received:
    4,570
    West Mids
    Country:
    Sandtex paint or similar.
  5. rasputine
    rasputine
    7 May 2016
    14
    Thanks Received:
    Country:
    Hi the cracks are not to deep but where its flaked there's signs of the brickwork showing, i did think about sandtex but am not sure if i can build up to the existing thickness of around 5mm, i wonder if i could add something to sandtex to give it some body and pre - seal the bad areas with PVA, my aim is to stop any rainwater getting between the base and the render.
  6. ^woody^
    ^woody^
    3 Sep 2006
    33,622
    Thanks Received:
    4,570
    West Mids
    Country:
    Sand/ cement then sandtex.
  7. rasputine
    rasputine
    7 May 2016
    14
    Thanks Received:
    Country:
    Yeah I tried a bad patch at the lower level, primed with PVA part diluted, and a mix of plastering sand and cement and a weak solution of plastisizer, it not a perfect match to the surface, but not a problem, have given it two coats of Dulux weather shield and when it all done it should look ok, scaffold goes up next week, thanks for your input.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
