    Dismiss Notice
External Garage / Workshop Electrics.
Discussion in 'Electrics UK' started by Carl1973, 14 Apr 2015.
  1. Carl1973
    Carl1973
    4 Jul 2012
    18
    Thanks Received:
    Lincolnshire
    Country:
    I have to run a power cable from my house to garage, the distance is approximately 12 M.
    It would be a pain to bury the cable due to the distance also being concreted. I am aware that over that distance it should be 3.5m high and supported on a catenary wire but it is not practical due to the height of the garage..
    Are there any other solutions?
    I would also like to run a further power from the garage to a workshop further down my garden, this can be buried easily enough but any suggestions on how to link the power would be appreciated so I am aware of what it entails.
    Thanks in advance.
  2. Sponsored Links
  3. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,565
    Thanks Received:
    2,132
    Oxfordshire
    Country:
    Before you start.
    What will be the total maximum demand (in amps) for the garage plus workshop?
    No point doing anything until that is established. From that information you will need to calculate the size of cable that you need.
  4. Carl1973
    Carl1973
    4 Jul 2012
    18
    Thanks Received:
    Lincolnshire
    Country:
    Garage will be two strip lights and just a single double socket to be used for the odd powertool and possible welder...
    Workshop will be set up with similar lighting. and 3 double sockets for a table saw, chop saw, router etc....
    The garage electrics would not really be in use whilst in the workshop and vice versa..
    I am also rubbish at multi-tasking so short of a battery being on charge and 1 power tool running that would be about the maximum load but I am not sure what each item would draw..
  5. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    Solar power, wind turbine, hydro etc..
    So in short if you do not have a solid structure to fit to, such as a wall (not a fence) they are about your only options
  6. Carl1973
    Carl1973
    4 Jul 2012
    18
    Thanks Received:
    Lincolnshire
    Country:
    So I bite the bullet and channel out the concrete to run it sub-surface....
    would it be practical to run it from a 45A RCD in the house to a Garage Consumer Unit in the Garage and out of that to a Garage Consumer Unit into Workshop..
    What size / type of cable would be recommended.
  7. Sponsored Links
  8. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,565
    Thanks Received:
    2,132
    Oxfordshire
    Country:
    • Thanks Thanks x 1
  9. Carl1973
    Carl1973
    4 Jul 2012
    18
    Thanks Received:
    Lincolnshire
    Country:
    I got my my TLA's muddled, but I didn't post on here to be ridiculed...
    Work will be done by a part P qualified electrician, I was just doing my homework!
    I'll just go elsewhere..
  10. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,565
    Thanks Received:
    2,132
    Oxfordshire
    Country:
    Fair enough, but your electrician will have to sign a certificate that says that HE/SHE designed, installed and tested the installation.
    HE/SHE will also know that the CPD at the origin is there to protect the cable. So the size of the cable has to be determined before anyone thinks about if the device should be a 6A or a 45A whatever.
    For instance
    is a very broad brush indeed.
    Some just plug in to a 13A socket, some need a much larger dedicated supply. You would still need CPDs with C or D curve so that they can withstand the inrush current.
    There's lots, lots more to consider…
    So, get your sparky to determine what you need, you won't get the answers from an Internet forum.
  11. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    Then you won't have been disappointed.
    In which case...
    When you get electricians to come and quote for the job they may well have ideas, as they can see the environment and we can't
    That will be the electrician's design and construction decision.
    My advice would be to ask the electricians to quote for taking meter tails into a switchfuse and supply the outbuildings from there, not from the house CU.
    The one chosen by the electrician who will be signing certificates to say that he did the design, that his work complied with the regulations etc.
    OK - here's some for you, if you want to learn more about what's involved:
    Going elsewhere won't alter the fact that the electrician you use has to be the one who does the design etc or he won't be able to certify the the work.
    • Thanks Thanks x 1
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
