Extra battens for PB vs Thermal Bridging
just that the difference is negligible in the studding of a wall. Ie it won't lead to thermal bridging. Think log cabin.
Jeds and FMT were making the point that timber is poor as an insulator when compared with PIR/PUR. There is bound to be cold bridging by the timber when such thermally dissimilar materials are adjacent to each other.
It's not that poor an insulator to make any difference. If it is - then tell me by how much compared to steel, brick and concrete. (Which we still use occasionally).
That's not the issue; it's poor compared with PUR/PIR.
Compared to concrete it is warm, however you should ask yourself why you can get cold spots showing through the plasterboard under a flat roof when there is only insulation between the joists and none under. :wink:
Ahem, excuse me chaps, but you'll probably find the cold bridge is located at the fixing nails/screws. As joe 90 rightly say's wood is an insulator not a conductor, full of trapped air (in the cellular structure) apart from when the timber is vacuum infestation treated then the cells are filled with a fluid which finally sets. This can act as a partial conductor for cold, so in fact you could be viewed as correct depending how you look at it :mrgreen:...pinenot :roll:
Well, as for me I was a joiner for more years than I care to mention - Site Manager - Projects Manager - qualified M.Sc in sustainability for the built environment ~ how about you? :P
Cheers...pinenot :wink:
Is your degree in one of those subjects with "Studies" after it, or a proper degree?
I'm struggling with that. I presume you must be familiar with heat loss calculations. But if you were you would know that thermal bridging through timber studs and joists is a significant factor and it is standard procedure to calculate it out.
On a back garden office? I'm struggling with that too. :roll:
No need to struggle. Heat is lost through garden offices as well.
I guess he'll have to demolish it then and start again if it's that serious. :?
That would be one solution. Or he could make a minor alteration to his design (i.e. as he was originally asking about) and that would be fine as well.
You guys! :roll:
Still,thanks for a 'lively and informative discussion'.
I did a little bit of stocktaking this afternoon and I have just enough 18mm OSB3 to clad the inside on the longest and weakest side. The one with the windows. The timber build is three sides extending a block structure as I said, out by 3m and 6m wide. So now that I have OSB sandwiching my studs and insulation I've pretty much got the ingredients of a SIPS board and (dare I say) maybe a little stronger.
Should be no way that'll get pushed over in the strongest gales now. PB over that and everyone's happy.
Thanks all !
