extractor fan help
13 Jun 2006
Manchester
i have a plug socket in my kitchen thats spured off a plug in the next room, can i replace this socket with a fcu and wire that upto a switch to control an extractor fan ?
if i can is the wiring simply live and neutral ?
and lastly, assuming the above is ok, can i run 2 extractor fans from the same fcu, with a double switch ?
1/ yes
2/yes
3/yes, providing you do not exceed the rating of the switchfuse spur. (13amp).
RMS
Fantastic, thanks for the help.
ive got one more question, the extractor is going to be inside a cabinet approx 4ft square, and used to vent the air from it. inside the cabinet will be a marine sump below my marine aquarium, which contains salt water at 26*. is a normal extractor fan up to this or should i use a bathroom one ?
it will be extracting the air to a large room that has an external extractor if that makes any difference.
and do bathroom extractor fans need wiring any differently ?
