I do wonder whether people perhaps take the requirement to comply with MIs too literally. The spirit is clear, and most people would want to comply with that spirit - but it does seem very odd that manufacturer's can 'make up their own requirements', which potentially go beyond what BS7671 would otherwise require, yet effectively acquire 'the power of BS7671'. In an extreme case, I don't think an electrician would have much of a leg to stand on if (s)he did something which was clearly wrong or dangerous, arguing that (s)he was obliged to do it in order to comply with BS7671 'becaue the manufacturer had (incorrectly) instructed it'!Yes, annoying, isn't it? You go over the top with the cooker circuit in your new kitchen, just in case - you run a 10mm cable on a 50 Amp MCB. You pop out with the missus to choose your nice new cooker and when it arrives the instructions tell you you should only connect to a 40 Amp, 6mm circuit. You're not ripping the 10mm out and yet you're not complying with the manufacturers instructions. By not complying with manufacturers instructions you're not complying with BS7671, so you can't sign off your EIC.
Great, aren't they - manufacturers can request any old twaddle that they like, probably without having a clue about electrics in the first place, and you can't question it or do what you think is better because of a couple of lines in BS7671.
Kind Regards, John
