Extractor Fan (Kitchen help Needed ?
24 Feb 2011
Gwent
Ok, so im needing help here on the wiring of the Fan. Please check my picture. Im looking to spur off the ring main, will this be safe for a fan ? And is this the best way to do it ?
Thanks for any Help all :D
You can install a Switched fused conection unit from socket as a spur and use this as an isolation switch and to down fuse, then route the cable as your drawing.
Then either a socket outlet or an outlet plate for the connection behind the fan.
It must be mentioned that the work is notifiable and the need for RCD protection maybe needed, depending on the method and cable used in the installation.
Links
http://www.diynot.com/wiki/electrics:part_p
http://www.diynot.com/wiki/electrics:installation_techniques:walls
