I solved my problem yesterday(see prvious posts) twas only a neutral wire had come loose.
I need a bit more help. as usual a simple job changing an extractor fan in en suite has turned into a major job. Problem is when I checked in the attic whilst fixing above problem I notice the wiring as follows lead from pull cord outside en suite to ceiling rose for light. Cable from rose to fan.No isolating switch. The wiring is only 3-4 years old as it is in an extension. I assume it need an double pole switch between the rose and the fan. Just need to check as if this is the case will get an electrician in if not will just connect the new fan up. Why has a switch not been put in in the 1st place ?
Cable to fan is one permanet live and one switched. Am isolating the permant live as new fan does not have a timer
Any help greatfull appreciated as I can then either finish the job or get a spark in
THANKS
THANKS
