Extractor hood duct - to reduce or to elbow?
28 Feb 2019
Hi All,
Lots of helpful discussion in previous threads, but my question is now specific.
Background: I have just redone my kitchen. In an effort to do all the dirty work up front I drilled the core hole for the extractor hood pre-plastering. 120mm straight (slight angle down) through two skins of brick, was going to use a solid duct through it for all the good reasons.
Problem: Some alterations to range cooker positioning occurred - which meant my lovely straight hole is now 25mm to the left of where it needs to be and I don't have enough play in the chimney enclosure to get away with it.
The question: Given the assumption that I am not trying to core another hole and mess up the outside brickwork, should I:
A) Reduce to 100mm, remaining straight
B) Knock out / drill out on the internal skin allowing an offset in either rigid or flexible but staying at 120mm
I know I will take a performance and noise level hit with either, but which will have less effect. I did try to calculate it myself, but I was struggling.
Thanks in advance.
Brad
C
Put the hood 25mm out of line with the cooker.
Thanks Chaps. Wonderfully conclusive!
I shall await a vote to sway. Anyone fancy pointing me at the maths to calculate the performance of A Vs B, albeit approximately?
James
There is no performance hit, nor noise increase.
This is what, a metre of duct from fan to terminal? You are worrying about nothing.
D change to recirculating
Just kidding, I'd go for B enlarging the hole and sticking with 5 inch pipe. As pilsbury suggests the "semiFlexi" hose is not a bad idea
