Extractor wiring
Status
Not open for further replies.
23 Mar 2005
l have a extractor fan ready to be put up in the bathroom, it's a single speed with timer and must be wired to a remote switch.The terminal in the fan has L/N/LS. What is the best way to connect this all up.
You have several threads on the same issue.
I am closing the others.
Mod Rupert
L = permanent live
N = neutral
LS =live switched
No , sorry what l meant RMS is wiring the circuit from the fan.The complete wiring needed from start to finish.
Crafty so l use 3 core cable and a triple pole isolating switch is this correct.The switch is connected next to the fan and then to the ceiling rose.Where is the best place to buy the switch.Or is there another way to connect up.
If l use a switched fcu l will no longer need a 3 pole isolator sw, so where would l put this and since l'm using 3 core cable how would l connect it up in the fcu and what fuse do l put in. :?
If you have a timed overun fan, you need to use a 3-pole switch, and 3 core and earth cable / 4 core flex from the ceiling rose.
Status
