Hi Noseall
I was wondering if you could help me ?
You kindly helped me the other day regarding my question about in situ cavity trays.
The building is a garage / workshop. To provide background ventialtion we have 9 x 3 air bricks fitted through the outer wall right through to the timber inner frame complete with plastic telescopic sleeves. The ventilation will be controlled via hit and miss screens.
The cavity is approximately 65mm deep and the building is to be rendered with wet harl with waterproofer in both the scratch coat and the top coat.
In your experience should we fit plastic cavity trays above each of the plastic telescopic vents complete with a weep vent ?
Cheers
Cheers
