Er not quite...we're are talking about gravity circulation through the cylinder primaries.
Circulation of boiler water to the cylinder coil (often a single coil) via 28mm pipework.
Many installations barely work due to the head/horizontal distance from back boiler to cylinder.
Boiler fires up...boiler stat turns off...heat exchanger losses heat via flue and repeat.
Gradually water circulates up and around coil.
Maybe 50% efficiency at best.
Concept fine when coal and gas were really cheap.
