F&E Tank overflowing
3 Oct 2004
Hey chaps!
Problem! Overflowing from the F&E tank... boiler on or off!
definitely a leak in the coil cos of the following...
return piping from the indirect cylinder to the boiler was replaced recently on (advice by yes! British Gas Engineers) and when reconnecting found clear water trickling from return outlet. Ohh the heating system was drained totally so it was bone dry.
Is replacing the cylinder a tricky job? I have done loads of pipework in the past but not a replacement tank. Are there regs?
Cheers fellas n galls!
Just get the cylinder connectors right! Parallel threads only, and usually the indirect(boiler) connections are special cylinder-connector fittings.
