F62 on vaillant
  • Thread starter Thread starter ALEC1
  • Start date Start date
A
ALEC1
Any one know the procedure for testing whether its the gas valve or the PCB????
Talk to the boiler in a calm voice and ask it nicely what the problem is. If you are polite enough it will answer you through its aura :wink:
sorry this shoild be in the CC not the public forum...
mods please delete thread...
Usually faulty PCB.
Does it come up immediately its powered or only when a demand for heat is given?
it doesn't have weather compensation... its numpty on off stuff...causing a lot of cycling....not my install I might add, I had to sort out the UFH....
I am a bit lacking when it comes to repairs...installed as they do in Germany and probably the rest of Europe with compensation controls these boilers are highly reliable....
On/Off controls are operating as intended.
Internal blocking codes result from a wrong/poor system design.
No Tony. That's not what a blocking code is.
In that they don't necessarily mean a fault.
I was asking what the difference is in terms of the operation of the boiler. .... Other than the pump demand ;)
