When my central heating suddenly failed during a recent freezing cold night, the fault was soon found - a loss of mains into a Siemens remote timer. No circuit RCDs tripped in the main distribution box. A local jobbing electrician did a temporary fix by running an extension to the timer along the floor from the mains in an adjacent room, so thankfully the heating works again.
He proposed returning to fit a new small distribution box inside that airing cupboard which houses the timer, hot water cylinder etc, by cutting into the power supply to the immersion heater, but I have my doubts. I'm not certain he's qualified to certify this new work, and anyway shouldn't he be concentrating on finding out where the mains wiring has become disconnected, broken or (most likely) chewed?
I could ask a trusted, fully qualified, previously-used installer instead, but I know they won't be available (even to inspect) for a few weeks, although that isn't a problem. What would you suggest I do? And what should I expect them to do?
Your advice would be greatly appreciated.
