The wife reported a burning smell in the kitchen the other day which we tracked down to the plug on the washing machine. The pug was clearly wrecked so I cut it off but I was interested to find out why it had failed so I cracked it open.
I can't seen any obvious reason for the fault. I assume there must be a poor contact somewhere which has caused excessive heating. My best guess is that corrosion has built up between the fuse and the contacts, does this sound about right?
The real question I suppose is do you think the washing machine is on the blink? It's not blown the fuse and it isn't tripping the RCD, other than this is seems fine.
Cheers
Cheers
