Hi All,
I've been doing a lot of research on here and found some great info (for which many thanks to all!)on a small false-ceiling project for a galley kitchen with the intention of fitting halogen spots.
I've now got the gist of attaching a frame to the walls at about 250mm down from existing ceiling (can't attach anything direct to concrete ceiling in 1920's block) but was wondering whether I could attach the joists to the perimeter frame using what we used to be taught in woodwork classes 40+ years ago (!) were called halving joints...ie a notch cut into the perimeter frame of half it's depth and a corresponding cut on the joist so that the two sit together. Apologies for the description and I might be talking about something that went out with the ark! The 'span' across the room is between 1200 - 1600mm (there is a section with a small alcove) and I was going to follow advice here of using 2 x 3 timbers for all parts and then plasterboard attached to the stud frame.
Main question's are: would this be a good approach? would it weaken the joints too much?
Many thanks for any help!
Mark
Mark
