- Joined
- 31 Mar 2012
- Messages
- 58
- Reaction score
- 3
- Country
I have a Vents TH1.5N, its a fan controller that has a run on timer and humidity sensor.
It works, with regards to time and humidity as expected.
But what happens is whenever another item in the house, no matter which circuit is turned on, the controller starts the fan.
This was initially installed by an electrician in new house wiring, we put it on another circuit and the same. I returned home and tried it... same again. Contacted retailler who sent me a new one.... same again.
It has L, N and LT(switched live) in and works as expected when you use LT as switched. The output only has 2 poles for the fan and the fan works.
If we got L and LT confused, it would just turn off as soon as the light/switched live was off right?
Any idea whats up? I've tried them both in two different houses with the
same issue!
same issue!
