Hi all,
I have just purchased a fantasia ceiling fan with light and am having some issues wiring it up. Please help!
The room has 2 ceiling roses (one of which I have changed for the fan) and 2 switches that are wired so that either switch can be used to switch off the lights.
I initially wired the fan to the switch feed. The fan (which is remote control only) will only work if the 'lights' are switched on by the wall switch. No good as turning the second light off with the switch forces the fan off.
I then wired the fan to the loop feed instead of switch feed. Perfect! The fan operates perfectly. However, now neither switch works when I try to operate the remaining ceiling light (ie it is permanently off).
Have I somehow 'broken' the circuit? How can I get around this? Any help here would be really appreciated,
Thanks guys,
Crackles
Thanks guys,
Crackles
