thatbloke your right, I was going to suggest that, farrow and ... are well over priced. Undercoat the area that is giving bother, sand it and then apply the rest.
I have just had a major problem.
New skimmed newly plasterboard walls, dried for over 3 weeks.
Some Tetrion "deep" filling"
Applied 20% mist F&B primer/undercoat, which went on fine with roller and brush around edges.
( as recommended by F&B for their emulsion)
Filled small indentations and small amount of flaking with Tetrion, sanded and dried.
Applied second coat of F&B primer, areas where I filled have flaked.
Contacted F&B and apparently Tetrion filler is too alkali for the primer!
Any suggestions on how to fill the flaked areas completely flat and what with so not to have to strip whole wall and repaint!
