I have two wooden outbuildings with apex roofs, so 4 sides/lengths of guttering to fit. So far I have only done 1. The fascia boards are not vertical, instead they are at 90 degrees to the rake of the roof. The angle is only slight, and the fact that the gutting also slopes slightly (the outside edge of the gutter is fractionally lower than the inside edge) does not affect its performance. What DOES matter is the fact that any downpipe connected slopes 'into' the wall instead of being vertically straight downwards.
I did foresee this problem as I was fitting the guttering, and I nearly opted to fit a wedge-shaped shim at each gutter clip to bring the angle back true, however unless I get shims 3D-printed, it's difficult to find or fabricate something of the exactly correct angle. So I carried on with the job thinking "I'll worry about the downpipe angle later - how hard can it be?".
I had assumed that there was such a thing as a downpipe connector with an adjustable angle (perhaps with a section of corrugated plastic) to adjust for the difference, but I can't find such a thing. Fixed angled connectors come in 30 and 45 degrees only. I therefore want to stop and think before I carry on with the other 3 lengths.
As far as I can see, my options are:
- Take the guttering down and fit a (20 degree?) shim at each clip as described above, to bring it true.
- Fabricate my own angled downpipe coupling with butchered parts and UPVC cement.
- Let the gutter drain into a hopper, and connect the hopper to the (vertical) downpipe.
