We've had a shower installed as part of a loft conversion. The problem is that the water doesn't drain out of the fast flow trap quickly enough.
Behaviour is as follows:
Video of behaviour:
The run to the vented stack pipe is 40mm diameter with a gradient of 25 mm per meter.
Sounds like there is a high point causing an air lock when the trap is installed? I'm unsure of the mechanics of it and why it blocks when the trap is installed. Without the trap, water drains with no problem.
Builder is confused by it and I'd like another opinion.
We've got a WC basin connected downstream of the shower trap and we undo the bottle trap to allow air to vent. It didn't make any difference to the drainage from the shower trap.
The trap type allows water through a cylinder section into a 'mini bucket' which overflows into trap and water exists via waste pipe. No hair or dirt in it.
Suggestions so far has been to cut off 15mm of the cylinder section from the fast flow trap. Did that, no impact.
Any ideas for further investigation or potential fix?
- Turn shower on
- Waste doesn't drain, shower tray fills
- Take out waste, bubbles/gurgling noise
- Water drains ok
- Put waste back in when water flowing
- Waste works as expected - water drains fine
- Turn off shower and water drains
- Gurgling noise from waste
- Turn shower on and waste doesn't drain again, shower tray fills again
Video of behaviour:
