fault on isolating transformer
26 Nov 2005
Dorset
can someone help me with this question please.
I have an isolating transformer to BS 3535 25V, which has a fault. What is the correct logical sequence of inspection and tests I need to carry out on this piece of equipment ? And would a multimeter be the correct test instument to use for these tests?
the transformer is being used for IP fated equipment within an inspection pit of a domestic garage i.e two bulkhead lights. its also has a socket outlet. NB this question theory based only and the particular fault is not stated. i have to determin the correct logical steps to inspect and test inorder to find type/reason for fault. (BS7671 doesn't seem to give details) can you help?
What have you been taught so far that you are supposed to have remembered or made notes about that would help you answer the question?
