Ok having a bit of a tough time with this cooker. The cooker side is not firing half the time I fire it up,there is a good spark on it, new nozzle, the correct oil pressure, and the motor works fine.
The second burner does not work at all. The motor works fine, good spark, and there is pressure when I hold a magnet to the solenoid stem, and cause it to fire. I thought it would be the solenoid, but there is no pull when I put a screwdriver in the solenoid coil, and I replaced the solenoid to try and still not working. I disconnected the solenoid coil from the plug in cable to it, and connected my multimeter to the live and neutral on the plug that connects to the solenoid, and there was no power through the cable when it tried to fire. What would cause no power to the solenoid coil?
I hope you can give me some ideas. Never worked on a Stanley cooker before, and don't like the idea of all the parts being wired in to a plug which travels to the control box. Worried there is a fault there, and I don't know how to find out where if there is a fault with the wiring connecting the burner parts to the control box. Thank you.
