Hi There,
Firstly, I hope you had a great Christmas.
I had the above boiler fitted in June of this year and it failed on Boxing Day with a F28 Fault Code, which is failure to ignite.
I have had a Vaillant engineer visit my property to investigate the cause and he reckoned it was a Faulty gas valve so one was ordered as he didn't have one on his van.
Another Vaillant engineer visited this morning to fit the new gas valve but same problem exists. He replaced several other parts, including PCB, Electrode, Mass Flow Sensor and cable assemblies, but problem is still there. He then said that he was convinced that there's a problem with the Flue. He told me to contact my installer (since they don't go as far as the Flue) and so I duly contacted him. He came over this afternoon and checked the flue and all is ok. He also reset/changed various parameters on the boiler and also checked the flow of Gas into the boiler. There is a slight fluctuation apparently but he says it isn't enough to prevent the boiler from firing up and is within tolerance. He also found a F54 fault code logged when in the installers menu. There is also a Spanner symbol on the display that the engineer was unable to get rid of, even by setting the service interval.
So, back to Vaillant I went and they have now ordered another 8 parts to fit so I need to wait for them to arrive so the engineer can book a visit to install them.
So, I have now been without heat and hot water since boxing day and have no idea when the engineer will be back to 'hopefully' sort the problem.
I thought I would ask on here in the meantime if anyone has any idea as to what may be causing the problem? The boiler is basically igniting but going straight out again.
Thanks very much in advance for your help, it's most appreciated.
Regards,
Rob.
Regards,
Rob.
