I've recently been researching a new boiler etc and part of the drive is because we got the annual review from our first year in the house recently. The gas bill was massive!
I complained the first time we had a bill but they kept fobbing me off with "it all balances itself out over a year" - I was expecting a big fat cheque back but instead the direct debit went up a bit!
3 bed semi, insulated loft, double glazed, room stat @ 15-16, bedroom rads off (we like it cool) and the heating's been off since February. The house seems to require very little heat input and maintains a pretty stable temperature.
According to the meter we used 29,500kW last year, about £1100 worth!
The meter readings used were actual readings and that averages out @ 2.64 ft/3 per day pretty much for each quarter's bill last year.
I've been monitoring it for the last month taking daily readings and we've never used more than 1.5 units in a day and some days as little as 1 unit.
Average is about 1.4 over the last month.
Our last house was the same size, older and less well insulated and cost us about £450 a year in gas, dropping to about £400 with a new boiler.
Next door have the same heating, boiler and DHW system - they were done at the same time. Until recently they had no loft insulation and older single glazed windows, have the heating on all day and only spend £450 a year on gas!
The only thing I can see that can possibly explain it is if the meter jumps up only once in a while but jumps up a large amount - otherwise it's not adding up?
Anybody come across anything as bizarre? I've had to pay for a meter check but if it misses it jumping up, I'm not sure they'll find anything.
