Hi
I've got a very frustrating Baxi 105e which seems to have a hot water sensor issue.
Every so often the hot water goes cold, then hot, then cold etc but it does not happen every time. When this happens you can hear the boiler ignite to heat the water then it cuts out and tries a few times before igniting again.
And on occasions the water stays cold, the dhw sensor led flashes and the boiler does not ignite. If you unplug the cable in the dhw sensor & plug it back in the light goes out and the boilers ignites again.
So all in all it's very frustrating!
Is it an issue with the dhw sensor, the cable that plugs in to the sensor or the circuit board?
I replaced the sensor about a year ago, it was fine for 6 months but now the issue is back. Was I just unlucky and got a dodgy sensor (cheap eBay one) or is the sensor a red herring?
Cheers
Adam
Cheers
Adam
