This has been asked before, never seem to get a problem solver,for my problem.
Heating runs fine, hot water flows whilst the boiler is alight for heating. as soon as heating reaches it's temprature flame goes out, get no domestic hot water with heating\hotwater switch in either position. 60 degree light flashes error.
Diverter valve seems work as it should??. Both plungers come out micro switches work, Continuity across dhw microswitch when plunger out, sending signal to circuit board.
could it be that either the flow sensor on the cold water inlet pipe or the dhw temprature sensor on the dhw outlet pipe not allowing the boiler to ignite.
Bill
Bill
