Faulty Triton Topaz T100i
5 Feb 2011
London
Hi there
I have the above shower fitted (a while ago)
every time i turn the dial a ER code comes up...
But the main problems is ... when on High Switch... the heat will go up very hot and then the Auto Reset kicks in.... water turns cold and then very hot agian and resets.... I have had the front panel off and when the system resets itself i get a small spark from the back circuit board top centre I think near the unit marked Heater 2
Any suggestions grately appreciated
I gather the circuit boards on these can be very unreliable.
On something so risky with water and electricity together I do hope that you are competent to work on them.
Tony
