- Joined
- 27 Jan 2008
- Messages
- 27,555
- Reaction score
- 3,331
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
OK, easy enough to fit a cooker unit, but that means 16 amps, not a 13 amps supply. I am happier to have my iboost+ supplied with a 13 amp supply. It is an expensive lump, I want it to have a 13 amp fuse, even if there is a 16 amp RCBO feeding the FCU.
I would not think my immersion heater runs that long? 35 kWh over 28 days is 1.25 kWh per day average. It will start to use power on a sunny day around 11 am, and it will be using way under 3 kW to start with, so highly unlikely to draw 3 kW in daylight hours for more than ½ an hour, at night it can draw 3 kW for 5 hours when on off-peak, but unlikely again to draw it for more than ½ an hour as only topping up.
I have seen these
It just seems daft to me, we have used FCU for years, what has changed?
