At my place of work (Built 2005) we have a wet room with an electric towel warmer in it. A recent PIR recommended that this towel rail be protected by an RCD.
There are no RCD's anywhere in the electrical distribution system, which is comprised of offices upstairs and engineering workshop downstairs. So, we are considering replacing the existing FCU with one that contains an integral RCD. However, the existing FCU is used as the main operating switch to turn the towel warmer on and off.
I was wondering if operating an RCD so frequently was a good idea, but after looking at a Powerbreaker unit, it actually says on it "test before use" so using the RCD as the regular on/off switch would make sure that this was done, however, if for any reason the RCD failed to trip when tested, then it would not be possible to turn off the appliance, which sounds a bit dangerous. Is this right?
The FCU is connected to a 32A ring supplying sockets in an upstairs office / server room.
