Have a couple of fire doors fitted with intumescent strips but have been informed they must also have a smoke strip. It's an old house and the gaps were Ok for intumescent strips but not for smoke brushes. Any ideas? Have seen these "Surface mounted fire door seal kits - 60 minute- fire & smoke". Are they any good?
Yes, we've tried them. As I say it's an old house and there are uneven gaps between the door and frame. That's ok with intumescent strips which will expand to fill the uneven gaps but when we fit a smoke strip you might be tight in one place and a gap in another. These surface mounted strips look like they would solve the problem but was wondering why they are not more widely used.
Brooks has only one size & Buckleys have various withs but the pile is the same. Have ordered some of those surface mounted strips as they got good reviews.
If you need to find a tradesperson to get your job done, please try our local search below, or if you are doing it yourself you can find suppliers local to you. Select the supplier or trade you require, enter your location to begin your search. Please select a service and enter a location to continue... Please Choose... Plumber / Gas Engineer Electrician Builder Decorator Builders' Merchant Plumbers' Merchant Tile Supplier Flooring Supplier Start Search Are you a trade or supplier? You can create your listing free at DIYnot Local
