Feasibility and cost of replacing breeze block wall
30 May 2008
Wiltshire
We have a 1950's semi detached house. It's a standard red brick exterior and is not rendered.
On the eastern wall we have what was originally an outbuilding with a pitched roof to the house. It's much more than a lean-to - it has brick walls and tiled roof, and we use it as our utility room. One of the attached files shows the current elevation.
We are looking at knocking this part of the building down, and building an extension, where the pitch of the roof is rotated 90 degrees, inline with the roof line of the main house. As shown in the attached plans.
The problem we have is that the eastern wall of the house directly under the existing pitched roof (ie. in the loft space of the outbuilding) is breeze block. I've attached a photo of looking up through the loft hatch. The area of breeze block runs the full width of the outbuilding, under its pitched roof.
If we go ahead with the extension as planned, we will be left with a lot of ugly breeze block being exposed.
My question is, is it easy/feasible to replace the exposed breeze block with red brick? I know small amount of brick work can be removed and replaced, but this feels like a substantial (and structural !) amount of brick work replacement.
Is it do-able? Will it add considerable expense to the build?
Cheers
Existing elevations:
Proposed extension:
Problem area:
Thanks very much for your swift reply. I didn't even know such a thing existed!, but thats looks like a very viable option. I'll look into that; thanks
