Hi all,
I'm looking to build an outbuilding at the back of my garden later this year when it heats up again but am unsure as to which material to use to build it?
The outbuilding will be used partly as a summer chill out room and partly as storage area with a small workshop.
I'd like to install shelving units and screw these into the walls for stability too.
I'd rather just have 1 skin of breeze block/concrete block on the external walls and so am wondering if concrete blocks would be the best things to use? As I'm not a builder, I'm not skilled at laying bricks/blocks and don't want any unstable walls and so am liking the idea of the larger 9" sized breeze blocks rather than using the thinner 4" concrete blocks to construct the walls out of.
But when it comes to shelving and racking, I'm not sure that the breeze blocks will be up to taking these screws?
The blocks will also be rendered on the outside and inside so as to give them a nicer look and make them waterproof.
Which blocks would you guys suggest? Which do you think would be better suited for this application?
Many thnaks.
Many thnaks.
