Fence Knot Hole Repairs
29 Jun 2012
Lancashire
Hi
The fence at the back of the house has a dozen or so knot holes. Which i'd like to repair as they are at eye level and just peeping holes.
It's a wooden fence put up by the home builders.
Once filled the fence will be painted / preserved
One idea i had thinking that it might take on which ever stain better is to Temp fix something on one site of the hole. Make a mixture of wood glue and saw dust and use that as a filler
But i'm not sure how that would behave / react to to the weather
So looking for suggestions which will be as natural as possible one stained
Wood Filler ?
Nadeeem
any flush repair has a 50/50 chance off lasting more than 1 year
a flush repair that looks nice has probably a 25% chance off lasting more than a year
the only way you will find out is by trial and error
something like a 2 part filler may be best
my suggestion is to make the "plug" about 5mm thicker on both sides then taper in flush about 10mm beyond the the edge so you have a disc 20mm bigger and 10mm thicker tapering all round untill flush with the wood no step but enough lip to hold in place
Try Isopon P40 fibre glass filler, other makers have equivalent at a reduced price.
Score the contact area timber well with a knife or hacksaw blade. Force filler into holes, allow to harden, sand and primer. You will have to paint I'm afraid.
Do a test piece (including painting) first and leave it to weather, see what you think.
Mixing sawdust, I'm not sure ..........
https://www.google.ie/search?q=isop...s=org.mozilla:en-US:official&client=firefox-a
