Fencing Height Sloping Rear Garden
8 Oct 2016
Hi guys can some advise me on this please.
Using 6ft fence panels with 1ft gravel boards on a slight slope about a 3-inch drop per panel
Setting the top of each panel at 6ft 6in (2m) from the higher post
Sinking 6 inches of the gravel board into the high side and 3 inches into the low side so there are no gaps underneath
Stepping the panels down cleanly along the slope as it drops
That will leave the higher post 6ft 6 and the next post at 6ft 9. About 3 inches higher than legal limit but due to burying gravel boards rather than a gap at the end it will look cleaner. Any advice? Is this the right way to go about it?
I have already had the 6ft panels and 1ft gravel boards delivered. Will the 6ft 9inch post height be a problem?
your fine its panel by panel when stepping down with the top off the panel up the slope no more than 2m so higher bottom end is correct regardless off actual height tother end ;)
