Hi all, I hope you can help.
I haven't erected a fence before so could do with some help please!
I've decided to go for a 6ft fence above ground level, in a hit & miss arrangement for the rails to allow the wind to pass through. The total length of the fence would be just over 19ft. I know I need to dig 2ft into the ground to set the posts. I've been told the quick-setting post mix is good to go for.
The trouble is that the fence is going to be put up on a slope. At the highest point, the end post needs to be 6ft above ground level, so 8ft in all. How can I measure exactly horizontally and accurately from the top of the post at the top of the slope along the 19ft length to determine how tall I need the post at the bottom of the slope to be?
The post at the lower end of the slope may need to be 8ft or 9ft above ground level to maintain the same height as the first post at 6ft above ground level.
I know you can gradually step the panels/rails at each post but I'd like to maintain the same level across the whole length.
Where do I stand with the local planning office if the height of the fence at the shortest post is 6ft?
Many thanks. Any help is much appreciated, J.P.
