ferroli boiler31c
the ferroli boiler is recently installed it fired up for about a hour and was purged properly, the inlet pressure is ok and pressure at metre is ok. The problem i think is the gas valve i just thought someone on here might of had the same problem in there time. However the technical engineer is coming out to have a look.
If you are gas registered then why dont you register for the Combustion Chamber where trade questions should be asked.
If you are not registered then why are you messing about with gas appliances?
Iam registered do you want my id number officer?
had one 12mths old . pcb fault and gas valve sticking. try hair drier on gas valve.
Maybe i dont want to go on the combustion chamber, but if you want to check me out feel free????
Try hitting the reset button for one second. You might need to do this three times.
I've just gone through a world of hurt with one of these babies.
Just out of context but WHO ARE THESE PEOPLE THAT FIT THESE ****E BOILERS!feroli and biasi,ikon 23-28t's.they all politely need unscrewing from the wall and taken 2 the scrapyard!!
