Ferroli Roma
26 Sep 2007
West Midlands
Hello All
I have recently visited a Ferroli Roma which i am repairing free of charge for a colleage. I seem to have no gas present at the outlet of the valve and was wondering if anyone knew a test procedure i could follow.
Because it is a friend i want to make sure i dont incur any extra costs than i have to.
many thanks
Jasper
You don't appear to be qualified to work on gas - call a boiler engineer in.
I am a fully qualified corgi registered engineer, I specialize in installations and not boiler repairs.
I joined this site because i was told the people were helpful.
Is this the case?
Is this the case?
Well yes but read your original post and I think you will get the same impression of not knowing anything regarding gas. If this was true then you were really given the best advise!
As a gas person would you not agree that in the name of safety that was in fact sound advise??
The Roma 55 (G.C. 41-267-05) is a permanant pilot model so do you have pilot lit or not? If no does it light while gas valve button is depressed?
Yes i agree, that would be first class and responsible advice if you think a person is not qualified.
There is no pilot lit, and does not light when gas valve button is depressed,
Fan is running and there is gas present on the inlet side, when gas valve button is depressed there is no gas present at the outlet side.
I was wondering if i had to replace the complete valve or wether i could strip it down and replace a component, I also wondered wether it may be a faulty overheat stat.
Thank you
jasper
Hi Dave.
Thanks for the reply will check for voltage this afternoon when i go back.
much appreciated
Jasper
