- Joined
- 10 May 2016
- Messages
- 61
- Reaction score
- 0
- Country
I have just had a set of patio doors installed into and extension. It means the old door on the other side needs closed up, either with brick or timber solution. I know i could do this by taking out the frame completely, then bricking this up with brick/blocks, then render. Not keen on this as it would mean a lot of cement mixing.
But can i do this instead with a timber frame, to close out the void?
As i understand, it would be timber frame, then plywood, then DPM or some sort of breathable membrane?
Only thing is, the rest of the extension is pebble dash. So can i apply a similar finish on top of timber based solution, after closing up the wall void?
Any feedback appreciated.
