filling ahole in the tile
5 Nov 2012
there is a hole in the tile where the rail is drilled into and the hole has gotten bigger and i was just wondering how i would fix it, bog it or replace the tile?
Is it that the hole is no longer holding the fixing secure for the rail or just a matter of making it look neater?
If the latter, grout it with same colour as tile.
If it's a loose fixing, it is likely you will need to re-drill for larger sized plug an re-fit rail.
