filling gaps in chipboard flooring
24 Apr 2008
UK, Wittering, West Sussex
i have some flooring chipboard 22mm thick 2400x600 - which is fine - BUT where I intend to join with another piece along the edge - i may have a slight gap , not a problem really as it will be covered by base units and away from view
the chipboard is 2400 x 600 and the room is 2630 - so will have a small gap of 230 to fill - allowing a 10mm gap for expansion
i have cut off the join on the 600mm end and my plan was to fill that with a spare 2400x600 sheet - cut up - but long ways - so i will have a piece 2400x220 to run down the side of flooring and wall
now the edge is not going to be perfect - so i may have a small gap - which i could fill , as thats where the vinyl will be
the walls are being plaster board and skimmed so 9mm ish -
maybe something like this
thoughts welcome
EDIT
I have been using CT1 for years now - first started to use on cast iron gutters in 1997 - and used for lots of jobs over the years
THEN along came BT1 for bathrooms and used that and excellent as well
NOW searching for an answer here - i come across FC1 - form same people - Filler and chalk (upto 25mm gaps ) - seems this will be my answer
and now that its all availble from toolstation (where when they first stocked there was a local rep - instore as they put in display units - and how i found out about BT1
https://www.toolstation.com/fc1-the-ultimate-all-in-one-filler-caulk/p42672
expensive - BUT i have always found CT1 does the job even in WET gutters
ok, i have that glue
i'll have to think how that would work in my application
i was not plannign to glue - i'll ask that as a separate question
i only had D4 - and its OFF anyway
so I have ordered some D4-PU everbuild Polyurethane Wood Glue from toolstation - just going off to get when open @7am - thanks
and some FC1 - for around the doors
wow - that stuff works well, got 4 sheets down so far - and gaps filled with the foaming glue - and just wiping off excess with a rag
floor absoultly solid and no noise at all so far
just 6 sheets plus infill to go
Spraying with water first helps. I helps to accelerate the PU glue curing process. I would be tempted to let the glue expand and then sand or scrape away the excess. Glad it has worked for you.
thanks - too late now 6 down and just about to move the fridge freezer onto it in 30mins or so and then done for the day
another 4 to lay tomorrow - i needs a lot of scribing - but these are all good and straight in - then the gap to fill all along the edge
but thanks for the recommendation
really please with it
Fair play.
The gap along the edge- If you are using pu foam, spray the plaster and flooring with water, it will aid curing AND the adhesion.
Best of luck.
